I've been searching all night for a discussion on how to wire a power disconnect toggle into the cabinet next to the Jensen radio. I saw it earlier this week, but I cannot find it.
Does anyone have any instructions? How to identify the power line? Where to source the toggle switch?
I have a 2016 T@b.
Thanks
Steve & Sherry
2016 T@b Q
Lakeville, MN
2 ·
2016 T@b Q
Lakeville, MN
http://www.autozone.com/electrical-and-lighting/rocker-switch/dorman-red-led-glow-round-style-rocker-switch/412545_0?_requestid=2332581
My understanding of wiring leads me to this. Cut the power line to the stereo. Crimp a blade connector to each end of the cut wire. The incoming power connector is attached to the load connection on the switch, the outgoing connector to the stereo is connected to the accessory connector on the switch.
Did you connect the ground on the switch to anything?
2016 T@b Q
Lakeville, MN
2016 T@b Q
Lakeville, MN
Here is the 12v switch next to the Jensen unit.
View of the opening for the switch (have not sized it yet for square switch):
Main lead that powers the Jensen (note wire crimp under thumb). the other end of the crimped wire goes to the new 12v switch.
View of the cigar lighter black and red leads. Follow the red lead back to a factory crimp. that crimp should also have the red wire going to the Jensen (marked "12v DC Switched").
(My Jensen is one that you can dim the blue light, but can’t turn it off.)
Did you find the 400 wiring similar to Tabaz's 320? I'm no pro by any stretch. Would those pics posted above help if I were to tackle this?
Would you happen to have any photos of your install or advice?
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
2013 Tundra TRD 5.7L
Massachusetts
2019 320 Boondock Edge - Sold Jan 2022
Massachusetts
Pardon my stupid questions, it's looking to me like I'll have to install two separate switches, one for the TV and one for the Jensen, correct? I was hoping that since they are "connected", I could install one switch for both.
Is it easy to see where to tap in on the back of the Jensen? When you drill your switch hole, is there anything you have to "look out for" behind? I'm not good with power tools, and am scared of electricity when I'm messing with wires. Did you all disconnect the battery first? Is the "ground" easy to wire up?
https://www.amazon.com/12V-Inline-Switch-iCreating-Connector/dp/B0782JXQNP/ref=sr_1_8?keywords=inline+12vdc+switch&qid=1581611969&sr=8-8
Is this where I would plug in the 12V Inline switch (red arrow) on the back of the TV? It looks like that switch mentioned above doesn't require cutting wires, correct? Just plug it in?
Ok, now the Jensen switch. @DenisP thank you for the link. I'm searching for one like your photo - but no light.
I come up with the wood that I'll have to drill into, being 7/16" thick (pink arrow). Does that seem correct to those of you who drilled? What size Hole bit did you use please? I really am clueless when it comes to tools and handyman (handyperson?) stuff. Is the big black cable where you cut to put in the Jensen switch (yellow arrow)? I see the skinny blue wires go to the light switch, and I see the HDMI cable.
https://www.amazon.com/TWTADE-Solder-Rocker-Switch-KCD1-X-Y/dp/B07XC5KB8D/ref=pd_sbs_328_4/143-7743903-5173920?_encoding=UTF8&pd_rd_i=B07XC5KB8D&pd_rd_r=12e3cede-79d9-45ef-9f29-a2a0622fd236&pd_rd_w=mDOkQ&pd_rd_wg=28MTs&pf_rd_p=7cd8f929-4345-4bf2-a554-7d7588b3dd5f&pf_rd_r=3Q42PQAP8N73X5WAAJW3&psc=1&refRID=3Q42PQAP8N73X5WAAJW3
cherrs
If you don't want to drill a big hole in your cabinets, I got a toggle switch with a surface mount bracket from NAPA to mount a switch on my truck dash.
Tampa FL
@Tampakayaker I'm interested in my options, given my low skill and knowledge level. What are the particulars on your Surface Mount Bracket? Am I only needing to tie into the Ground and +12VDC wires (two only)?
You just need a simple single pole single throw 12V toggle/rocker switch. 2 connections for the wire and a simple on/off action. You only need to break the 12V positive wire to connect to the switch. You don't mess with the ground. Some of the fancier switches have a small LED light in them that would require a ground, but since you want to eliminate a drain on your battery you wouldn't want them. You can find a simple switch on Amazon, at Wal-Mart automotive aisle or any auto parts stores. The toggle type would be the easiest to mount since it would require 1 hole to be drilled. A rocker type would usually require a square/rectangle hole to be cut. Look for a toggle switch that has a neck long enough to go thru the thickness of the wood where you're mounting it and to allow the nuts and washer to fit. Whatever switch you purchase there should be information on the diameter hole you need to drill to fit the switch thru. Remember the switch will come from the back (where the wires are connected) thru the front of the mounting surface. I hope this makes sense. You can google toggle switch and see how people install them on various applications. The one below has wires connected that you would just have to cut and connect the 12V positive lines to.
Tampa FL
