In the Middle of Winterizing!!!!
Hi all. I'm in the middle of winterizing....blew out the taps, closed the valves for winterizing, poured 2 gallons of diluted pink anti-freeze into the fresh water tank....turned on the water pump....and I'm getting nothing. I waited at least an hour and still nothing. The water pump is working and things are gurgling....but nothing comes out of any of the taps or the flushed toilet.
I DID open my cold water drain valve (under the seat with the blue and red pipes) and drained it....could that be a problem? Seems unlikely.
How long does it take to pressurize?! Thanks
Should taps be open or closed when pressurizing...mine have been closed.
2015 T@B Max S.  TV: 2015.5 Volvo XC70.
  • webers3
    webers3 Member Posts: 450
    My experience is that you are going to need more than 2 gallons in the tank, probably 3-4. On my 320 the pump stops pumping but the water level gauge shows almost 20% left in the tank
    I assume you bypassed the Alde by opening the bypass valve and closing the hot and cold supply valves.  But, I think you need to close the drain valves in order to be able to use the plumbing to deliver the AF.  If you were just using the pump to take a shower, you wouldn’t open that valve.
  • Deb55
    Deb55 Member Posts: 293
    I had to put more than 2 gallons to get it circulating. I think we ended up with 4. That said, we probably could have used 3 if the camper had been level. Are you level?
  • ELK
    ELK Member Posts: 213
    I suspect that if I lower the nose, I met get some action!
