Clamshell Seal Maintenance
NomadPilgrim
Member Posts: 111
What is the factory recommended maintenance for this seal? Starting to get some wear and breakdown of rubber. 2016 CS-S. Also getting floor buckling in the kitchen there’s no sealant along the floor/wall seam. Dark part is vinyl floor
2016 T@B Maxx CS-S following a 2008 4Runner Ltd
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
An email to tech@nucamprv would get an answer from the factory.Verna, Columbus, IN
You should probably treat it regularly with 303 spray.1
Melts goop under hinge
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho0 -
I don't have an under hinge seal cause mine's a Dutchmen, so I put this rubber seal over the top
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1 -
I did the same based on your model.
John & Cheryl
2007 T@B ClamShell by Dutchman "Goli@th"
2018 Chevy Colorado V-6
Edmond, OK1 -
The official word is to use GEOCELL MHRV 2300 sealant on it.
