Clamshell Seal Maintenance
NomadPilgrim
NomadPilgrim Member Posts: 111
What is the factory recommended maintenance for this seal? Starting to get some wear and breakdown of rubber. 2016 CS-S. Also getting floor buckling in the kitchen  there’s no sealant along the floor/wall seam. Dark part is vinyl floor
2016 T@B Maxx CS-S  following a 2008 4Runner Ltd
Be brave. Take risks. Nothing can substitute experience.-
Paulo Coelho
  • Verna
    Verna Member Posts: 6,876
    An email to tech@nucamprv would get an answer from the factory.
  • tabiphile
    tabiphile Member Posts: 473
    You should probably treat it regularly with 303 spray.
  • NomadPilgrim
    Melts goop under hinge
    Paulo Coelho
  • Mouseketab
    Mouseketab Member Posts: 1,262
    I don't have an under hinge seal cause mine's a Dutchmen, so I put this rubber seal over the top
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • cmac
    cmac Member Posts: 90
    I did the same based on your model.
    John & Cheryl
    2018 Chevy Colorado V-6
    Edmond, OK
  • NomadPilgrim
    The official word is to use GEOCELL MHRV 2300 sealant on it.
    Paulo Coelho
