Adding shelves to 400 kitchen cabinet
Michael49
Member Posts: 140
I'm thinking of adding one or two shelves to the cabinets above the kitchen counter in our 400.
I was looking at some pin type shelf holders that we have in our house and was thinking this would be a simple and adjustable method of adding cabinets - is this a stupid idea in a RV though? Would they bounce around while driving?
https://www.amazon.com/VAKOGAL-Nickel-Plated-Material-Anti-Corrosion-Furniture/dp/B07NTDTFHP?ref_=s9_apbd_omwf_hd_bw_bAVdrSF&pf_rd_r=HA8MBNP6WJTEFMTRD0T8&pf_rd_p=85120e2e-6359-5f4d-9780-f551724321ad&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=9628895011
Any other simple adjustable methods that would work in a RV?
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
They would stay out if you drill a slightly undersize hole to get a tight fit in the pins. Then notch the shelf bottom to sit on the pins, so the shelf stays put too.
You should have no problem at all. I have been using wire shelves from Lowes that just sit on the bottom of the cabinet and they haven't moved at all.
I thought those wire shelves usually snapped in though.falcon1970 said:You should have no problem at all. I have been using wire shelves from Lowes that just sit on the bottom of the cabinet and they haven't moved at all.
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline. -
@Michael49, I have used these expandable shelves in my 400 above the sink since I took delivery almost 2 years ago. It stretches across both cabinets giving me plenty of room for everything.Verna, Columbus, IN
This is the wire shelf I am using. There are about a gazillion styles, shapes, and brands. Everybody seems to carry them in one form or another.
@falcon1970, I’ve used the white ones before and they dump their contents too frequently. These others are flat footed and they stay in place. It was a great find.Verna, Columbus, IN
We also used the wire rack approach as shown by @falcon1970. Works great for us in that upper cabinet. To hold plates, bowls, tumblers and coffee mugs.
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
