Adding shelves to 400 kitchen cabinet
Michael49
Member Posts: 140
I'm thinking of adding one or two shelves to the cabinets above the kitchen counter in our 400.
I was looking at some pin type shelf holders that we have in our house and was thinking this would be a simple and adjustable method of adding cabinets - is this a stupid idea in a RV though? Would they bounce around while driving?
https://www.amazon.com/VAKOGAL-Nickel-Plated-Material-Anti-Corrosion-Furniture/dp/B07NTDTFHP?ref_=s9_apbd_omwf_hd_bw_bAVdrSF&pf_rd_r=HA8MBNP6WJTEFMTRD0T8&pf_rd_p=85120e2e-6359-5f4d-9780-f551724321ad&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=9628895011
Any other simple adjustable methods that would work in a RV?
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
They would stay out if you drill a slightly undersize hole to get a tight fit in the pins. Then notch the shelf bottom to sit on the pins, so the shelf stays put too.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1 -
You should have no problem at all. I have been using wire shelves from Lowes that just sit on the bottom of the cabinet and they haven't moved at all.1
I thought those wire shelves usually snapped in though.falcon1970 said:You should have no problem at all. I have been using wire shelves from Lowes that just sit on the bottom of the cabinet and they haven't moved at all.
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.0 -
@Michael49, I have used these expandable shelves in my 400 above the sink since I took delivery almost 2 years ago. It stretches across both cabinets giving me plenty of room for everything.Verna, Columbus, IN
This is the wire shelf I am using. There are about a gazillion styles, shapes, and brands. Everybody seems to carry them in one form or another.
@falcon1970, I’ve used the white ones before and they dump their contents too frequently. These others are flat footed and they stay in place. It was a great find.Verna, Columbus, IN
We also used the wire rack approach as shown by @falcon1970. Works great for us in that upper cabinet. To hold plates, bowls, tumblers and coffee mugs.1
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
