Jack Pads - Which are the crowd pleasers?
  • pak
    pak Posts: 132
    I carry plenty of 16" 2x6s. They are not slippery, cheap, no big loss if I leave them and very easy to replace. There are times when several are needed under each stabilizer. Granted they don't look like much but they are functional.
  • ChrisFix
    ChrisFix Posts: 743
    @pak
    Thanks. And given you're using them, I take it 2x6 is big enough? I had been thinking of boards, and thought maybe 2x8 or 2x10, but smaller would be better of course for packing.
  • AirBoss
    AirBoss Posts: 740
    I'm using 2x8's cut into 12" squares. Screwed one on top of the other so have a couple 4x8, others just single. Stained to match color of rig ( left over stain from house...might as well).
    Been lucky so far...haven't need one under stabilizers but will have to make a few more I guess.
    San Diego, CA
    www.airbossone.com
  • Bayliss
    Bayliss Posts: 1,532
    edited May 2020
    @ChrisFix, I use the stackable leveling squares for the four stabilizers, but like the Curt jack foot for the tongue jack (link is below.)  I carry a thick wood block to rest the jack foot on, but you could also use the stackable blocks as a support base.  I carry two packs of the stackable squares (approximately 18-20 total) so I always have plenty available, and often use most of them.
    https://www.amazon.com/Curt-Manufacturing-28272-CURT-Jack/dp/B004QEJ6UQ
    Greg & Marlene (Tucson, AZ)
  • MASH
    MASH Posts: 3
    I have dutchman T@B so not sure if this applies.
    I added BAL pads to the stabilizer and don't need anything else.  They're permanently attached and work great.
    https://www.dyersonline.com/bal-stabilizer-pads-set.html
    BAL Stabilizer Pads Set
  • CrabTab
    CrabTab Posts: 457
    We cut out and attached 3pcs. of 3/4" plywood to the stabilizer pads to reach terra firma from boondock height (arrows point to mounting screws).
    Plywood is through bolted to keep them together.
    2019 320 Boondock Edge
     - Sold Jan 2022
    Sharon_is_SAM Posts: 10,035
    @MASH - the Pleasant Valley Tabs came with discs already mounted.  Of course, on the Boondock models, they don’t always reach the ground😁
  • Dalehelman
    Dalehelman Posts: 2,414
    We carry 2 but rarely need them. Only needed if the ground is really soft.
    1. Hash  T@B Fun
  • ChrisFix
    ChrisFix Posts: 743
    Thanks everyone.
    I will definitely get the Curt Jack Foot that @Bayliss suggested...seems like a good tool to have in the toolkit!
    And I have some pieces of 2x lumber, so I think that I'll cut that up for now and see what I need as I go.
    Looking for that balance of having what I need but not carrying my entire garage with me...which I'm sure is what you've all gone through as well!
    Thanks for sharing your experiences.
  • GatorEgg
    GatorEgg Posts: 482
    I have one set(4) of plastic “LEGO” pads.  But I also carry eight blocks of 2x6 cut into 6” squares.  If I need more I scrounge rocks or what not from campsite area.
    Odessa, Fl.
  • Tampakayaker
    Tampakayaker Posts: 558
    ChrisFix said:
    Thanks everyone.
    If you don't want the jack foot, there is a dog bowl type of device that the wheel sits in.
    Camco 44472 Wheel Chock With Rope.
    Available on Amazon (of course)
    Tampa FL
