I have cell booster that I want to mount on a mast when we get to the campsite so it is not permanent. I need to run the cable into the Tab on a temporary basis and I am looking for bug-free, leak-free ideas. Has anybody done this? I know I can crack a window and run it through the bottom but that doesn't get me past the shade/screen.
Thanks
Jeff & Amy
Now in Manistee, MI
0 ·
One owner has put permanent coax bulkhead coax ports through the door for use with Amateur radio equipment, a bit more permanent. If you are really concerned, you could buy a spare door to have on hand if you ever wanted to remove the mod.
https://www.weboost.com/products/drive-x-rv
I like the idea of a fitting style passthrough. The Aldi door is a good idea.
Jeff & Amy
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
It looks like the WeBoost may be 75 ohm the same as TV cables typically, BUT I don't have one to know for sure, point is know before you just connect it up.
https://www.wilsonamplifiers.com/blog/50-ohm-vs-75-ohm-which-is-best-for-you/
Jeff & Amy
Odessa, Fl.
