Frigidaire AC Problem
We have a recently purchased 2014 CS-S with the Frigidaire 5000 BTU wall unit AC. We used the AC for the first time this weekend (our second "shakedown" trip) and had the AC compressor cut out twice, while the AC fan continued to work. Turning the unit off for an extended period allowed the compressor to start again.
Both failures occurred with the thermostat set to the maximum setting and outside air temps in the 95-100 degree range. There were no failures when the air temp was cooler. The air filter is clean and nothing was blocking any of the internal or external venting.
Since we live in the desert Southwest, this is a huge problem for us. Anyone else experience the same type of issue or have any ideas of what the problem might be and a possible solution?
Many thanks for any assistance!
_________________________________________
Chris & Cristy Gullett
2014 T@b CS-S Max
