Nuts & Bolts - metric or standard?
source3source3 Member Posts: 144
edited June 2015 in Trailer & Towing
First, I searched the forum and had no luck.
Are the bolts and nuts metric or standard?  I should be picking up my T@B Outback up soon and want to have the correct tools for the trip home.  I am only concerned about structural components that may cause a road trip to come to a hault.  TV is metric, so that is what I commonly carry.  I carry a star lug nut wrench so the tire is covered in case of a flat.
Andrew P.
Durango, CO
2015 S Outback
    On the body of the T@b they are mostly square headed. I will check the frame, but IIRC, they are standard.
    Source3, while I have a Silver Shadow and not a T@B, both are made in the same factory in Ohio, and the trailers are locally made in Ohio also.  I carry both metric and standard wrenches and sockets, and I have used the standard ones on the few bolts I've had to "mess" with.
  • source3source3 Member Posts: 144
    Verna said:
    ...I have used the standard ones on the few bolts I've had to "mess" with.
    Thanks.  I figured that I would have to start carrying standard sockets.
    Andrew P.
    Durango, CO
    2015 S Outback
  • sabelsabel Member Posts: 283
    Source3,
    If your still interested, we have an Outback too and all of the bolts are standard.
