How to Get Bleach Mixture into Tank For Sanitizing 2021 t@b 320 Boondock!
andyboy
Member Posts: 120
I was all set to sanitize my water tank today only to find out my flexible funnel with a rather small spout couldn't be inserted far enough for any of the mixture to get inside the tank.
Any suggestion?
2021 320 S Boondock
Subaru Outback XT and Honda Passport
Des Moines, IOWA!
See your trailer Nautilus manual, it explains the process you need to use.
Did you receive the Nautilus instructions? Looks like you are supposed to use your pump to siphon from a bucket.
https://us.v-cdn.net/5021717/uploads/editor/i2/ifvg1dabfs8z.pdf
Thanks Sharon.....it did not get the Nautilus instructions. Actually nor the Jensen sound system or TV, which I downloaded. Guess I'll be downloading the Nautilus manual too. Thank you for your help.Denny16 said:See your trailer manual, it explains the process you need to use.
I checked in the main manual and it really didn't cover it. Unless you mean the Nautilus manual...read above.
2021 320 S BoondockSubaru Outback XT and Honda PassportDes Moines, IOWA!0 -
We downloaded the Nautilus manuals for the 320 and 400 under the Category “User Manuals/PDF Files...” then look for “Plumbing Resources”.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes, I was referring to the Nautilus part of the manual. Didn’t realize it was a separate manual. There also has been several discussions about doing this with the Nautilus System.
One more question on this topic. After I siphon in like a gallon of the bleach solution, can I hook up the hose to spigot and fill the rest? Turning off the pump when disconnecting the siphon part and then turning it back on for the spigot water. I can monitor the tank level from the panel inside.
*** I just realized the OP was about the 2021 with the Nautilus system. I’ll leave this for the non-Nautilus amongst us.****
I use a kitchen oil/grease separator similar to this one. I run some water in. Then the bleach, quickly followed by more water to dilute the bleach. I find it to be a very easy way to be very careful with controlling the bleach.
@andyboy...if you go the nucamprv.com website and scroll to the bottom..click on your appropriate trailer...manuals are also there...easily downloaded for future reference and late night reading..it really appears to be a very cool system...looking forward to having hot water in aT@b says a current T@g owner... 😁Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada1 -
Yes! I found it! Seems like a great system. Thanks2021 320 S BoondockSubaru Outback XT and Honda PassportDes Moines, IOWA!1
@andyboy - yes, fill the remainder of the tank as you described.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
