Rusty water stain on exterior - how to remove?
JP2558JP2558 Member Posts: 237
The water hookup where we last camped left a water stain running from hose
hookup down to the trim. I tried straight white vinegar and that didn't work so I tried some lighter fluid and neither worked to remove this rust stain. Suggestions? My next option is Goo Gone but I'm afraid that might actually eat the finish.
Thanks, Jerry
  • BaylissBayliss Member Posts: 1,493
    @JP2558, I would give some cleaner wax (like Meguiars) a try.  I use Meguiars to wax my T@B (body and trim) and it works great.
    (I don't believe Goo Gone will be a problem with the finish, but I doubt it would remove a rust stain since that is not what it is designed for . . . . . . . . BUT, like any other chemical/substance, test it out first on an inconspicuous area, just to be safe.)
    Greg & Marlene (Tucson, AZ)
  • monamona Member Posts: 246
    Same experience. Awesome will remove stain on trim and side. I think I used glass top stove cleaner or liquid barkeepers friend on keder rail.
  • JP2558JP2558 Member Posts: 237
    @Bayliss - Thanks for the Meguiars tip - that did the job!
    Thanks, Jerry
    Peanut butter works on removing sap and tar from the TaB side.  You outfit on, let it dry and rub off.
