I've read where some are using this meter thingie to check power. ??? My husband says I should get this. Hate to sound d__b, but what is it? what does it do? why do/should I need one? And which one should I get? Martha '15 T@B CS Maxi
Martha, do you mean the surge protector? If you are going to frequent RV parks with power hookups you will need this. It basically protects your camper if the power at the park is not installed correctly.
M@rk and Donn@ : 2015 T@B S Max, Silver/Black, 2008 Toyota Beef Taco DC
Or, do you mean a little meter that plugs into the cigarette lighter socket and moniters the charge state of your battery? Both the surge protector and the battery are good things to have.
thanks, PXLated. Hubby and I have been talking about taking a ride to Camping World (about a 2hr drive) someday with paper and pencil and see what's out there. That should be fun!
I just installed the Progressive Industry, EMS-HW30C last weekend. It was not too hard. I use Bogart Engineering Trimetric 2025-RV to monitor my batteries.
I added one, and love it. I know what amount of power my items use, and I have zero fear about plugging into old power towers. This past week it did block me from getting power when plugged into my friend's outlet. Turns out his extension cord had the ground plug snapped off. We went another route. (Don't worry, I was only running the fantastic fan and charging my phone and the battery!)
LOCATION: Fort Raccoon; UNIT: 2014 T@b S M@xxxx; MISSION: To have fun, make a difference, and make some friends along the way. Organ Donor Recipient- forever grateful.
@jcfaber1or @XPADREXI think I am ready to think about installing a higher quality battery monitor. Am I correct in my understanding that the shunt needs to connect directly to the battery? So, in my case, The connection would go from the battery to the shunt and from the shunt to the battery cut off switch and then into the T@b where the Progressive surge protector is installed. Is that correct? Thanks
What? It's an upgrade (major) to my current battery meter. It drives me nuts to not know the true charge state without unplugging everything or turning it off.
The shunt is installed between the negative on the battery and all of the negative leads. Check out Bogart Engineering Trimetric meter. They are very helpful in installing their meter. The Progressive Industry device I purchased is to protect from wiring faults on the 120 voltage AC side not on management of the batteries 12 V side. We are camping and it got down to 28 last night. After running the 12V fridge, furnace, and CPAP we are at 85% of capacity this morning. Gizmo crazy maybe, but it is nice knowing the state of charge. Now our 200 watt solar will get it back to 100% today.
Haven't hit quite that low yet but did hit 32 a couple days ago. Don't have a CPAP but ran the Alde and fridge all night, woke up to 12.4 on my cheapy meter. Bright sun so my 120w got everything back to full before I packed up and hit the road. Here's another gizmo you guys need :-) ... Was in a truck stop this morning, saw a 1,500w inverter with a smartphone app for setting/monitoring.
Thanks! I knew that about the surge protector but just forgot.
I am looking at the Victronic, which also seems pretty easy but will look at Bogart.
I do my best to avoid using an inverter ad they are energy hogs. Would rather get a generator.
they look like this
http://www.amazon.com/INNOVA-3721-Battery-Charging-Monitor/dp/B000EVWDU0/ref=sr_1_14?ie=UTF8&qid=1434741622&sr=8-14&keywords=voltmeter
2007 T@B
Rockford, IL
2007 T@B
Rockford, IL
