Refilling water tank after dewinterizing and water exiting the exterior drain in back
jules2go
jules2go Member Posts: 172
Just trying to figure this all out and again am confused! I have put the valves all back into "camping season" mode and filled up the water tank. I turned on the water pump to run fresh water through the pipes, etc but noticed that water is going straight out via that clear plastic pipe that exits to outside, underneath the hot water tank and all those pipes. When I turn the pump off, the water stops flowing out, or if I switch the hot and cold valves to closed position it stops, too. Why is this happening? When it was in camping mode before, with the pump on, water wasn't coming out under the camper. I wish there was a video tutorial on the Tab 320 plumbing system but I haven't found one yet. Thanks in advance.
2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
