Inside Overhead Light STOPPED working because of a loose wire spade connector in the wall switch.
tinglebells
Member Posts: 14
Here is how we fixed our 2019 T@B S Boondock inside light that would not switch on (all of the other lights worked fine)
1. TURN POWER OFF
2. GENTLY remove the switch cover
3. Unscrew the switch from the wall using a SQUARE drive screwdriver
4. Wiggle the first of four spade connectors from the terminal (DO NOT REMOVE ALL AT THE SAME TIME)
5. LIGHTLY compress the spade connector with the needle nose pliers
6. Reattach spade connector to terminal and test that is fits snugly
7. Repeat for each connector
8. Turn on power and test the switch
Thanks for the help and advice from Dana at Missouri Teardrops
Missouri Teardrop Trailers
Phone:
1-660-909-3553
There really isn’t much to the switches as they are a rocker type switch. I just received one I ordered as I am running another circuit for a utility light. I’m glad things worked out for you.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ -
Good to know info, @tinglebells. I have made a note of it for future reference. Thanks!2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)
- 915 Tips & Tricks
