AIMS Inverter Fail
MischiefBrewingMischiefBrewing Member Posts: 30
On the final trip of the season, we pushed our luck and ran a hair dryer on high for a bit (boondocking of course). We got the dreaded beeping then solid tone and then completely lost the AIMS.  I checked the breaker while we were still at the campsite, but that wasn't it.  Did a bit of digging once home after winterizing and still couldn't identify the problem.  I absolutely hate that the unit's fuse is covered in paper since I can't find my tester, and hated even more that those fuses go for $13 or so and while it would be good to have a backup, I couldn't be sure it would solve the problem.  After some back and forth with Andrew from AIMS Power via email, I started following the lines to and from the unit.  I knew there was a secondary breaker, but totally missed the 150A Stinger fuse:
Yep, completely burned.  $8 and a week later, we're back up and fully functional!
Have to remind ourselves to keep the hair dryer on low from now on :)
