T@B 400 Factory-Added Custom Options
2»
  • manyman297
    manyman297 Member Posts: 1,433
    Denny16 said:
    @manyman297, the wire going from the external solar connector to the battery is no 8, stranded copper wire.  Many portable solar panels are supplied with no 8 wire also.
    That’s good. So you could add a pretty large panel if needed.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    Denny16 Member Posts: 5,431
    Yes, about 200-300 watts, depending on the solar controller size, a Victron 75-15 is good for up to 200 watts, and I think 200 watts in addition to the factory solar should be more than enough charging power for 200 amp battery bank.
