Winter Toilet Use
Hello All,
I have a TAB 320 and I would like to use the toilet in the winter. How much anti freeze should I pour into the black tank to begin with and how much should I us for each flush?
  • Michigan_Mike
    Michigan_Mike Posts: 2,858
    edited December 2020
    I would pour a gallon of the pink RV antifreeze into the tank and you could use another gallon to flush with as needed.  I’d also use either some liquid toilet treatment to eliminate odor or a similar powder based toilet chemical treatment for odor/decomposition purposes. 👍🏻
  • DougH
    DougH Posts: 1,110
    Most of us go for a 50/50 ratio in the tank with each flush.
  • AMC4
    AMC4 Posts: 5
    Thank You!
    Denny16 Posts: 5,430
    Also if the trailer is heated, leave the washroom door open enough to get warm air inside, this will help keep the black tank from freezing, since it is under the toilet above the floor, not under the trailer.
    cheere
