ATWOOD Hydraulic brake actuator parts
sov2
Member Posts: 2
Hi. Any suggestions to replace ATWOOD master cylinder, shock absorber.
Alex
Calgary, AB
2014 T@B
2013 Toyota Venza
Calgary, AB
2014 T@B
2013 Toyota Venza
Hi and Welcome to the T@B Forum
I have no direct experience however web searches note . . .
With Atwood out of business there aren't any exact replacements for hydraulic couplers generally available. Most web-articles suggest:
1] searching local boat trailer shops to see if they have old (dusty) stock.
2] doing minor modifications to other brand/model parts to fit your Atwood.
3] replacing full Actuator with an available today brand,
replacement cost should be <$200 or so + installation
DIY installation is possible (option I would select)Here's an Atwood exploded diagram, from
There is a good reference article here:Let us know your final solution.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
@sov2 - here is a Dutchman resource. There are some references to brakes here: https://tab-rv.vanillacommunity.com/discussion/6382/dutchman-t-b-resources#latestSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Hi. Finally its done. Demco # 8605001 works. Installation was't easy, you need to trim the top plate and replace the straight connector on 90 degrees (master cylinder).Alex
Calgary, AB
2014 T@B
2013 Toyota Venza
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
