Command hooks for stabilizer crank
PNWtabber
Member Posts: 492
I want to put hooks in the external access cabinet to hold the stabilizer crank (I have no idea what the correct name is) in place. I am hoping there is a command hook that will work, because I am hesitant to screw things into the cabinets until I know better what I am doing. Has anyone used command hooks to hold that crank and, if so, which command hooks work best for this application? Thanks.
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
What about the style that holds a broom handle..it still might be too big to grasp the crank..as it locks around the handle..Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada -
@PNWtabber, here are some ideas:
https://tab-rv.vanillacommunity.com/discussion/9309/storing-the-longer-stabilizer-hand-crank-bar#latest
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)
- 916 Introductions
- 72 Teardrop Groups & Links
