Tab 400 clears 97" ceiling space
Here's a mod I came up with to store our Tab 400 in our warehouse.  Started with a pair of 6" 150# blind flanges I got off ePray, drilled the 5 on 4.5"  bolt holes and the center hub then glued some 1/4" rubber matting around the perimeter of each disc for rolling ease on the concrete floor.  The disc/wheel is approx 11.5" OA and leaves about 3/8" clearance from the brake drum to the floor, maybe less.  The green stretch-wrap I put on to keep the rubber in place after applying contact cement - then just left it on.  Next time they come off I'll apply a coat of paint to make them look nicer.  I have about $ 275 in them but it beats paying rental for storage.  So we're keeping the T@B, it sat in front of our house last year and that's not allowed in our neighborhood, used the Conflu excuse to keep code enforcement at bay for a couple of months.
  • 4ncar
    4ncar Posts: 1,072
    Necessity is the mother of invention!
    2018 320S Outback
  • Would letting some air out of the tires provide enough clearance?
    Denny16 Posts: 5,430
    Not likely, as the TaB400 (non BoonDock) is 104-inches high, and you need to drop the trailer height by 7+ inches to clear 97-inch ceiling.  Airing out a 15-inch tire is not going to give you the needed 7-inches.
