Battery balancer
jcrystal
Member Posts: 32
I noticed on the Renogy website they recommend a battery balancer when running multiple batteries in series or parallel. Is this truly necessary for two 12 volts in parallel?
2021 TAB 320S Boondock
I have read that batteries in parallel, your 2 twelves obviously, can benefit most from a balancer. Running batteries in series is much less of a problem - hence why so many opt for 2 six volt batteries. (note: a single twelve or six volt battery is actually already a series of lower voltage cells mounted inside the same box)0
