Exterior Wall Frame Member Locations (320)
Tabaz
Member Posts: 2,421
Someone on the Forum posted some computer drawings showing the aluminum frame locations in the exterior walls. Please provide if you know where they are.
2016 Outback 320
Is this the discussion you were looking for @Tabaz ?
Clarification on Aftermarket Roof Rack Installation (vanillacommunity.com)
2019 320 Boondock Edge - Sold Jan 2022 -
@Tabaz, see the .pdf documents that are linked to near the bottom of page 3 in this discussion thread:
https://tab-rv.vanillacommunity.com/discussion/8012/grab-handle-for-2018-320s/p3
Not sure it is what you are looking for, but I have attached an additional document here as well.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
The exterior walls are Azdel/foam/fiberglass composite. Only aluminum framing is around the outer edge and around the windows and door openings, as shown in the PDF Bayliss posted above. Not sure what you want to do.
Yes! Thank you Bayliss and Denny - those are the drawings I was referring to. Thanks also Crab T@B for responding to my question. The door sidewall is what I was interested in. It looks like the screws holding the wood valance go into the Azdel - not the aluminum frame around the window. Will not be attaching anything even remotely heavy to the wood valance(s).2016 Outback 320
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
