Great tip for filling fresh water tank!
Trying to fill the 320 Tab water tank with a hose is almost a joke as the air blows the water right back out! I found that by using this
CAMCO 11691 RV WATER HEATER TANK RINSER
  I can get the water way down below where the vent is and no backsplash.  I clean it with bleach before the first use. Art
2019 TaB 320 S Boondock Edge
  • Tampakayaker
    This is similar, but smaller, less expensive, and has a flexible tube that goes into the fill valve.
    Available on Amazon
    Camco Water Tank Filler with Shutoff Valve- Quickly and Efficiently Helps Fill Your Water Tank and Eliminates Line Backflow - Lead Free (5/8" Tube) (40003)
    Tampa FL
  • CrabTab
    CrabTab Member Posts: 457
    I've had good success by not turning the spigot all the way open when filling from a hose. Less water flow seems to allow the air to vent and not blow back. It does take longer to fill, but my clothes stay dry.
    2019 320 Boondock Edge
     - Sold Jan 2022
  • teztab
    teztab Member Posts: 99
    Available on Amazon
    I also use the Camco water tank filler - compact, inexpensive and very effective.
    ScottG Administrator Posts: 5,692
    Tipping the trailer nose up seems to help also, as does blowing out the vent line prior to filling.
    Problems seem to arise when water sloshing in the tank backs up into the this flexible hose that vents the tank. The hose is not well positioned to self-drain (and may even be a bit kinked), and if it gets blocked it can inhibit tank filling and cause the dreaded splash-back.
  • Lisamorrisette
    Lisamorrisette Member Posts: 48
    This is great for using with a hose. Does anyone have a suggestion for how to fill from a 5 gallon jug? I picked that sucker up and tried to fill my tank and ended up with half the water on the ground, thought I was going to expire under the weight lifting it that high and tilting it when you are only 5’2” ain’t pretty.
    Furbug 2014 T@B S - TV Toyota RAV
  • rhyno
    rhyno Member Posts: 393
    edited March 2021
    If using a smaller jug is not an option, or if you don't have a power fill/pump siphon option on your T@B, you could use a picnic table or something to get the container high enough above the tank filler hole to allow you to gravity siphon the water from the jug to your tank.
  • Lisamorrisette
    Thanks will give this a try. I was wondering about a siphon.
  • Marceline
    Marceline Member Posts: 1,773
  • Tabaz
    Tabaz Member Posts: 2,420
    This thing works GREAT!  Hightly recommend it.  Put the brass end in the water and shake it a few times.  Syphon action starts on its own.
    2016 Outback 320
  • Dalehelman
    edited March 2021
    Got this at Harbor Freight for $9.99 or Bass Pro for $19.99 battery operated, and you can leave the jug on the ground.
    1. Hash  T@B Fun
