Stove top not working but heater is on propane
Hi there, I have a brand new 2021 320 and took it out for the first time. I went to cook dinner and the stove top would not light. There was no gas coming out. The alde system was working fine and running on propane. I shut the tank unhooked, rehooked and no use. When I got back home the stove was working fine. I was only at 3100ft which is only 1500ft higher than Phoenix. Also the camper was more level at the site than it is in my driveway. Could it be a regulator? Any ideas?
    Denny16 Member Posts: 5,431
    Sounds like a possible kinked gas line to the stove, or there was just air in the line, that needed to bleed out.  Check the gas lines for any possible gas leaks also.
  • manyman297
    manyman297 Member Posts: 1,434
    Air in lines can be deceiving and take a fair amount of purging to correct sometimes. Last year I thought our absorption fridge in our tent trailer was broken but it had a ton of air in the lines due to recently refilling our tank. It took maybe 2 minutes of holding the fridge valve open to get it to work again.
    2021 400 BD
    2020 Tacoma TRD Off-Road
