Bad Alde Internal Water Leak
Tabaz
Member Posts: 2,420
My Alde just sprang a water leak somewhere internally. With either city or fresh tank water being fed, water will slowly accumulate in the very small drip pan the unit sits on. Then weep out of the hole in the drip pan below the exhaust port. Turned off the hot and cold lines going into the unit, and the leak stopped. Will be removing the unit tomorrow and taking the cover off. Of course it is out of warranty. Any thoughts or suggestions will be appreciated.
2016 Outback 320
Location of leak. Exhaust hoses removed.2016 Outback 320
Oh, snap! Not how you wanted to start your weekend camping...😡
2018 320S Outback0 -
There is another thread about a water leak from a couple years ago. Will see if I can find it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Found it. Initially thought it was condensation, but then discovered an Alde leak (go to the last part of the thread.https://tab-rv.vanillacommunity.com/discussion/7304/alde-drip-pan
and @Tabaz you also had an event before here https://tab-rv.vanillacommunity.com/discussion/comment/126057#Comment_126057Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
Thanks Sharon for doing that search. Confirms my problem is a leak - not condensation. Will start removing things to find the culprit.2016 Outback 320
