TAB 320 Fresh Water Gauge
Lauinger
Member Posts: 38
I have filled my tank, let it gurgle to get air out and settle, run pump to charge the system and topped off but the fresh water gauge is just barely getting to the FULL indicator. It certainly seems full but the gauge seems off a bit. Its didnt do that last season.
Any thoughts?
Any thoughts?
If you opened the hot tap when you ran the pump you would reduce the fresh water tank by about 2.5 gallons to fill the Alde water tank - that could account for less than a full tank. Also, are you level? You can try to raise the tongue and add more water, too. Also, the tank monitor seems to work with a range of volume, so it is not terribly accurate.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
By raising the front of the trailer as far as possible I was able to add almost 4 gallons.
- Hash T@B Fun
