Battery
Just looking for some information/knowledge from the group.  We have a T@b 320 Boondock (2018).  We had the dealer fit it with two batteries.  Attached is a picture of one of the batteries and the other battery is the same size and make but just has the two positive (?) and one negative wires.  Just wondering about all the different wires, cables and what they all do?  When we disconnected the other battery there was a short red wire not attached to the terminal-that is how it came from the dealer-not sure why? I know these are naive questions, I am not a battery wiz, but just trying to better educate myself and learn more on how to take care of our T@b.  Does anyone else have this configuration?  Can you use just one battery if necessary if you have this configuration and how would that work?  I appreciate your input!
    pthomas745 Administrator, Moderator Posts: 4,658
    Hard to see in  your photo.  Assuming they are two 12V batteries?  Or, are they two 6 volt? The battery voltage would determine whether the batteries were wired in "series" or "parallel".  So....which is it?  6V or 12V?  The battery should be marked for it. (A picture of both batteries at the same time will show everything needed to solve your mystery.)
    The wires on the battery in the picture:  black wire is the negative battery cable.  On the right:  the positive battery side:  the green/red wire with the battery fuse in the little holder is the positive wire to the trailer.  (Trace that plastic wiring harness the wire goes into....it is heading to the battery switch along the back of the propane box.  The other "red" wire on the positive post is the solar port wiring.  The harness that wire goes into will head toward the driver's side of the trailer to the little "solar" port there.
    So.....you detached the "short red wire" from this battery?
    Hard to tell what you have without seeing both batteries, but since a group 27 battery is 12v, I am guessing you have two 12 volts wired in parallel.
    @Mherson50 - you can have two 6 v batteries wired in series to double your bolts and keep your amp hr capacity the same (12v is required to run your appliances, lights, water pump etc.). Or 2 12v batteries wired in Parnell electric.  Here is a diagram.
    I suspect the short, red wire may have been for the solar port - just trace it back to see where it leads.
  • Mherson50
    Mherson50 Member Posts: 3
    edited April 2021
    The batteries are 12 volt.  This is the other battery-I am assuming this is the correct set up?  Thanks for your help!
    Denny16 Member Posts: 5,430
    Then the batteries should be wired in parallel to get more amp. hrs, out the them.  Yes, you can also just use one at a time, if you want.  You can get a marine A/B/both/off battery switch, and hook it up to select either battery, both, or off.  This is a normal setup on a boat’s house battery bank where two batteries are used.
    @Mherson50 - I think the extra negative and extra positive go to your solar port on the side of the tub.  Can you confirm?  You may have to remove then replace some loom to figure things out.  Do you have solar or an inverter?
  • Mherson50
    Thanks for the input.  I have had everything hooked up as above and seems to be working great. I do not have a solar system.
