T@b Task Day
I finally added a battery cut off switch and mounted my fishing rod-flag pole holder (thanks, @dalehelman !) My flagpole arrived but I realized I also need a new flag. Hoping it dries off and I can get to my caulking work.
Good job!
Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 320 -
Post a pic of the flagpole set up - What flag ya flyin?0
I have to wait for the weather to clear; it started to rain.PXLated said:Post a pic of the flagpole set up - What flag ya flyin?
I will be flying the stars and stripes of the good old USA! 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I could not fully extend it due to overhead wires and tree branches. I used pipe insulation foam to snug the flagpole in the rod holder. The last picture is a close up of my wireless antenna (Ubiquiti Nanostation M2. I have one more piece to the puzzle arriving tomorrow and a new flag on Wednesday. I think I could probably rig a plate for the cell phone booster but not sure I will do that right away. The WiFi antenna is mounted to the pole with a mounting plate.
The setup looks good.
Sterling, VA0 -
So, did it all go together as easily as expected?0
Jenn, did you fasten your cutoff switch with adhesive?Kristi Des Moines, IA 2008 T@B L0
Yes, I used a 2 5/8" hole saw to cut the hole in the battery box cover moved the wire from the battery to the switch, added a tray cable from the switch to the battery, tested, and that was it.PXLated said:So, did it all go together as easily as expected?
Yeah, I used silicone, but might next to use gorilla glue, too. There is not a lot of surface area o. That switch to add the adhesive.IACamper said:Jenn, did you fasten your cutoff switch with adhesive?
Thanks. I used screws, but I'm nervous about the tips of them coming into contact with something electrical....Kristi Des Moines, IA 2008 T@B L1
Jenn, Gorilla Glue is great, but it's a little 'brittle' for flexible substrates. You might want to use a kind of construction adhesive for plastics. Dunno what tho... B-) I have this polybutylene stuff that sticks like mad, and stays rubbery/flexible, but you gotta buy a whole caulk-size tube.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Adhesive silicone chalk would work great for that. Keep in mind that you will have to cut it off if you ever want it off.0
IACamper said:Thanks. I used screws, but I'm nervous about the tips of them coming into contact with something electrical....
I got a little sloppy with my wrench when I was tightening down the nut on the battery. It woke me up, for sure!2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Been there, done that...will probably do it again. Be careful.Verna, Columbus, IN
Yeah, I wish I could say it was the first time.
Jenn, what do you mean by a "tray cable?" Thanks!2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
A heavy duty battery cable, like this one. I should add that I ran the switch to the negative side of the battery.kybob said:Jenn, what do you mean by a "tray cable?" Thanks!
