I have to wait for the weather to clear; it started to rain.PXLated said:Post a pic of the flagpole set up - What flag ya flyin?
I will be flying the stars and stripes of the good old USA! 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Yes, I used a 2 5/8" hole saw to cut the hole in the battery box cover moved the wire from the battery to the switch, added a tray cable from the switch to the battery, tested, and that was it.PXLated said:So, did it all go together as easily as expected?
Yeah, I used silicone, but might next to use gorilla glue, too. There is not a lot of surface area o. That switch to add the adhesive.IACamper said:Jenn, did you fasten your cutoff switch with adhesive?
IACamper said:Thanks. I used screws, but I'm nervous about the tips of them coming into contact with something electrical....
A heavy duty battery cable, like this one. I should add that I ran the switch to the negative side of the battery.kybob said:Jenn, what do you mean by a "tray cable?" Thanks!
