Filling Freshwater Tank in 2021 TAB 400
Zackanrbd
Zackanrbd Member Posts: 1
How do you avoid over-filling freshwater tank when filling from hose on city water connection?
  • justdoit70
    justdoit70 Member Posts: 56
    They don’t tell you that some one should check the panel as you are filling I had the same question. It fills pretty quick . If you fill from a 5 gal bucket via 12 v pump and a short siphon hose 4 buckets is good for a 400.
    @Zackanrbd -if the tank starts to overfill, water will start to exit the vent and you will see it on the ground.
  • 85Redwood
    85Redwood Member Posts: 52
    Once the freshwater tank is filled to capacity it dumps excess water to the ground...this alerts you that the tank is filled...you cannot "overfill" it.
    2021 T@B 400: boondock, 3-way fridge, microwave, solar
    2008 Toyota Sequoia 5.7 L
