Removing Friedrich AC in Floor cabinet of 2015 320Q
TheBellHop
Member Posts: 20
I’ve looked through the forum and cannot find how to remove a Friedrich AC from a floor cabinet…all seem to be wall cabinets with a face frame you can remove. Ours has no face frame holding it in and trying to lift it out doesn’t allow it to pull out…it’s like it’s attached at the bottom. Anyone have advice? I don’t have to dismantle the cabinet, do I?
2015 Little Guy T@B 320 Max White with Red trim
Pulled by a 2023 Toyota Tundra
Leaves on T@bventures from the Snoqualmie Valley, WA
Here is the response received from NuCamp when asking the same question. 2016 T@B 320 QMax.
I 2016 T@B 320 Qmax, 2020 KIA Sorento, The Woodlands, TX2 -
That worked! Thanks!2015 Little Guy T@B 320 Max White with Red trim
Hoping someone sees this thread and can help me find out what we can replace the ac with. I don't want it gone, I just might need a new one soon. Are these special RV air conditioners or just normal window units? We have a 2019 320 U so ac is on the floor and regular battery, not lithium, is there anything to worry about how much power a new one takes? I've tried searching but I am not great at that here. I must not be using the right keywords. I'll stand by and see if anyone sees this. Thanks!
We've slept in 36 states, 2 countries & counting0 -
The window units only operate via shore power so, no power issues. I think you have a 5000 BTU air conditioner in the Tab. Just find one that will fit and you’re good to go.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@ColleenD2 There are several threads with info about how to remove the floor AC's. Some of these older trailers might be slightly different, but these should get you some idea.
Towed by 2014 Touareg TDi0
