Lights out
jggigi2009
Member Posts: 6
So are lights will not work in our 2019 T@B 400 and we have checked g to uses and breakers which . I am Wondering if it has something to do with the inverter switch. However the light above my dinette and next to my bed are both working. We were plugged in to shore while camping this last weekend, and when we came home and started cleaning the lights did not work. Can someone please tell me where I can find the inverter and if it should be off or on. We have ability to hook up to shore here while we are not camping at home and like to leave it hooked up and run our air conditioner to keep it cool. Thanks for help!
Just to make sure you are on shorepower and not battery, turn off your battery switch. Lights still work? AC working?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes everything is working except for the overhead and cabinet bathroom lights.0
Check the fuses, these are all 12 volt lights. Fuse panel is located in the power distribution center in the curb side of the dinette seating area.
Brad2020 400 BDL aka "Boonie"
Concord, NC0 -
Checked all the 12volt fuses and they all seem good.0
@jggigi2009 - do you know what fuses correspond to these lights? If so, I would change that fuse, even if it looks ok.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
