We had our 320BD on her maiden off-grid voyage just last week - a Harvest Host location only a few hours from home. While we had great weather and a generally terrific experience with our T@B, there were a few relatively minor glitches, one involving the water supply.
I thought I filled up the water tank before we set out, but it turns out that, despite the interior display indicating full, that was a chimera. We were quite parsimonious with our use of water; no showering, very short rinses in the sink & sparse flushes of the toilet. Yet we got to "low" on the indicator after only a day.
When we returned home, I drained the grey water tank into a 5 gallon bucket; it got to only about half-full, maybe 2-1/2 gallons. For obvious reasons, I did not want to use the same technique to measure the water in the cassette but it was at most half-full, so about another 2-1/2 gals. I then opened the faucet on the sink and got only a quart or two before the water turned to a trickle and the pump started cavitating, which I took as indicating an essentially empty supply tank.
Overall then, water use was perhaps 5-1/2 gals from a tank that nominally holds 19 gallons. Obviously, the indicator was wrong. Is this an easy adjustment or does it have to go to the dealer for that? Is there any way other than using the indicator to determine when the tank is really full and just as importantly, any way to reasonably estimate of how much water is left?
https://www.amazon.com/gp/product/B007NHS9M4/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=knowledgeshar-20&creative=9325&linkCode=as2&creativeASIN=B007NHS9M4&linkId=eb188c6effa0de319131f48287398f65
I rarely trust the monitor in the trailer, although mine seems to be pretty accurate. I just fill the tank at a normal rate initially, but when I hear (through the water-fill tube) the tank approaching capacity, I slow the water down to help get the air out of the line/tank and continue filling until the water starts backing up through the fill tube. You can also try raising the tongue of the trailer a bit to get more water into the tank.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Greg & Marlene (Tucson, AZ)
