Help. Turned on pump toilet leaking in back
The first time I used my tab this year I turned on the pump and I could see water coming out from behind the toilet.  It was clear it was leaking.  Only when pressure was applied when the pump was on.  I can’t see behind it to see if it is coming from the line or somewhere else.  I took the hose off and could not see anything     Any ideas?  Dave
2017 CSS Max
    Sounds suspiciously like a cracked toilet valve due to trapped water that froze.  I think you need to remove the toilet.
  • ChanW
    ChanW Member Posts: 3,171
    edited August 2021
    @Herg, I agree with @Sharon_is_SAM.
    Pulling the toilet is quite easy, just two hold-down nuts. The seal underneath the toilet is simply a flexible rubber flange, no wax to mess with.
    I found the replacement kit for that valve on Amazon.
    Use Google to search for your toilet model.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Herg
    Herg Member Posts: 38
    Thank you. Are the bolts under the camper?
    2017 CSS Max
  • dragonsdofly
    edited August 2021
    @Herg, the 2 hold down nuts are on either side of the toilet base. They are at the toilet bottom level and are visible in the bathroom, probably under plastic caps. And only a small amount of t@b toilet yoga is necessary for removal. Technical difficulty and flexibility level is: beginner, but it does help if you have arms as long as an orangutan! Good luck. -Denise
  • ChanW
    edited August 2021
    Well, ok. I confess. It's true. I've often been compared to an orangutan, but usually only when dancing - not plumbing...  :s
  • Herg
    He he. Thanks. I just went out there. And I found the bolts.  Not sure what size but all I do is pull it straight up correct?   All I do is pull the seal straight up with it?
    2017 CSS Max
    Yep, though the seal may stay stuck to the hole. On mine at least, the installers were not at all stingy with the caulking when they attached the toilet flange to the floor.
    The seal is rubber (or similar) and can be reused if undamaged. However, chances are if you buy a replacement valve it will come with a new seal as well.
  • Herg
    Hello!  I have it off but I can’t see anything wrong.
    2017 CSS Max
  • Herg
    2017 CSS Max
    @Herg - this thread will help.  https://tab-rv.vanillacommunity.com/discussion/comment/92224#Comment_92224
    The crack may not be obvious.  The toilet valve is a weak link.  Just change it out.
  • Herg
    You guys are awesome.  Thank you!
    2017 CSS Max
  • BrianZ
    BrianZ Member Posts: 1,770
    Yep, there's the crack..
    After seeing some of these in this forum, I now pump some antifreeze through our toilet as part of our winterizing routine.
    -Brian in Chester, Virginia
    RV: 2018 T@B 320S, >100 mods
