Dutchman window replacement
KDCL
Member Posts: 3
I am the original owner of our 2006 T@B T1. I love this camper.
We need a new side window 18"Hx36"W. The latches on the window that we do still have are very brittle. I'm guessing that maybe those broke and that is the reason our missing window went flying off. So besides needing a new window, I'd also like to replace all of those latches.
I did email NuCamp and have contacted the T@B dealer in our area, but I have not been getting any answers. Can anyone help?
Given the lack of help we've gotten so far, I'm guessing the newer 320s have a different size window?
Thanks for any help!
Proud original owner of a 2006 T@B T1.
Here is a thread that suggests moving the trim: https://tab-rv.vanillacommunity.com/discussion/comment/154008#Comment_154008
And this one sounds like a nuCamp window can be MacGyvered to fit:
https://tab-rv.vanillacommunity.com/discussion/comment/41665#Comment_41665
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio -
Thank you Sharon.
We did finally get an answer to the size of the current T@B side window and it is about 3/4 inch wider and 1/2 taller (strut position is the same depending on how measured) than our missing window. We are ordering and hoping we can make it work.Proud original owner of a 2006 T@B T1. -
We had a similar problem and our dealer ordered a new window. Took D@isy in today for window installation and the new window will not fit. Ahhhh. So frustrated. D@isy is a 2007 DM T@B. The trim was in the way. I have left her with the dealer but they are not hopeful. I'll check the 2 sources above.
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
