Removing LP Hose from Manifold
I'm moving my LP tank a short distance, but need a longer hose between the manifold that's attached to the diamond plate on the front of the trailer and the regulator. The problem is that I can't get the pipe fitting out of the manifold. I'm not sure if it's the sealant that nuCamp used or if it's just over tightened. I tried heat with no luck. My biggest fear is stripping the screws attaching the manifold to the diamond plate out by using too much force. Anyone have experience with this?
  • AnOldUR
    AnOldUR Member Posts: 1,726
    I have to wonder what kind of Loctite stuff nuCamp uses on these fittings. Tried more heat and even liquid wrench with no luck. Turned out there was just enough play in the gas hoses to move the manifold over enough to get all the connections in place. Not ideal, but it's done. Second battery is where the propane take use to be. Tank moved to the left. Made the move because I wanted heavy batteries centered over tongue.
    a
