2021 Tab 400 Cool Cat thermostat question
rhyno
Member Posts: 393
I'm trying to find a bluetooth enabled thermostat and Dometic needs to know which control box the stock unit has? Does anyone happen to have this information for the 2021 model year?
I don't have model # handy, but this is the pic of the Cool Cat control on the 2021 400 BD, if it helps.
2021 T@B 400 Boondock - Chev Silverado 2500HD 6.6L
Montana USA -
thanks @BridgerSunset - Dometic is looking for some control box between the thermostat and the Cool Cat. NuCamp support told me just now that the thermostat plugs directly into the Cool Cat as far as they know. I may be out of luck finding a bluetooth solution for under $200. Too bad the Cool Cat doesn't support 3rd party BT/Wifi stats.
2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO -
@rhyno
I believe the t-stat is directly connected to the Coolcat. I remember this from installing the softstart. Look at the lower right hand corner...and you can see the t-stat connection.
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller -
I was looking for a Bluetooth solution and found this:
https://www.dometic.com/en-us/outdoor/climate-and-comfort/air-conditioners/air-conditioner-accessories/dometic-ct-single-zone-thermostat-164510Says “Bluetooth enabled” but when I google the model it shows discontinued.2021 400 BD
2020 Tacoma TRD Off-Road -
I think you are going to need the Cool, Furnace, Heat strip model for the Cool Cat AC, as it uses a heat strip for heating. You might want to contact Dometic before buying a new controller to get their recommendation.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Dometic recommended BT model 3316404.015, sold as a thermostat and controller box kit. It is "discontinued" on Dometic's website and costs $200-$250 where you can find it online but none seem to offer a decent return policy if it doesn't work out. That's too much of a gamble just to avoid having to get out of bed to adjust the temp!
- 916 Introductions
- 72 Teardrop Groups & Links
