2021 400 BD AC suddenly doesn’t turn on at all
kbdigitiqe
kbdigitiqe Member Posts: 163
AC worked beautifully in brutal heat wave last trip out, picked it up after sitting for a month yesterday and now it’s just blowing hot air.
Any quick fix tips or something we might be missing??
  • ChrisFix
    ChrisFix Member Posts: 743
    Make sure you removed the outside vent cover...
    I've forgotten to remove it several times - and you will get no cold air.
  • kbdigitiqe
    I did thanks though (almost did forget).
    I realized my fresh water tank is completely empty, I don’t suppose the cool cat needs water ??
  • kbdigitiqe
    UPDATE: thermostat is lit up but now AC doesn’t not turn on at all not even fan
  • ChrisFix
    edited August 2021
    The Coolcat does not need any water - that is at least one thing you can totally rule out.
    Have you checked the circuit breaker in the wiring control center (bottom of cabinet next to fridge)?
  • kbdigitiqe
    Aaaaaand the breaker in our garage had tripped… that’s why it stopped working  B)
  • bergger
    Glad you figured it out.  Yes that will happen if you are not on a dedicated circuit for the AC and if you turn on something else sharing it and too much power is drawn.  We have a 20 amp dedicated circuit for ours at the house and it seems to be fine, so far I have not tripped the breaker, with the AC running and the fridge, lights at the same time.  But on a side note I am curious if anyone knows how many amps the cool cat draws when the compressor and fan are running?
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
    Denny16 Member Posts: 5,431
    It is not so much (around 10 amps or less) whilst it is running, as the big draw in current is on startup, when the compressor comes on, that is when you will trip a breaker on n undersized power source.
