Problem Winterizing
Karm
Member Posts: 18
I have a Tab 320, 2021 and I am having a problem winterizing it. I drained all the water fro. the systems and I am now attempting to pump AF into lines. I attached my hose to the left nozzle and turned knobs to winterize and then turned on the pump. I hear the pump running but it is not creating any vacuum. I tried closing all water outlets and then opened one and that did not work. I tried starting the pump with all water outlets closed and then opened one and that did not work. I tried priming the pump by pouring AF down the hose and that did not work. What am I doing wrong? I called NuCamp and they did not help me.
Can I winterize the camper by just pouring AF into my hose with the hose hooked to the winterize nozzle?
Mark
Mark
@Karm - there have been several owners who have had the same problem. The pump is not priming. I believe the current recommendation is to pour AF down the short hose and blow into it while the pump is running. I think that should get the liquid down to where it needs to be and set up a prime.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Karm - yes, I'm one of those having this problem...and others. No response from NuCamp today. Thanks for this response @Sharon_is_SAM....every suggestion helps! You are all so wonderful to offer your experience....1
I had a similar problem this year....but only after I opened up a water line at the back of my Nautilus panel. When I first filled the system with anti-freeze the pump worked fine. Then I noticed two small leaks in the hose fittings under the seat. I disconnected the fittings to inspect them, then reconnected them. I tried to run more AF through the system to check the fittings and had the suction problem. I primed the pump, let it run, then opened and closed a faucet until it started pumping. I assumed that I let too much air into the system when I opened the lines...but then I wondered if the low friction properties of the antifreeze promoted the leaks and perhaps allowed additional slip in the pump. I didn't have the problem last year and switch antifreeze brands this year. I've never had the issue when pumping clean or sanitizing water. Just a thought.0
I wish they would just bring back the gravity fill outlet. Technology and new-fangled gadgets are great ... until they aren't. I like the "old-school" design of my 2019 400. I like being able to see, touch, and directly manipulate my valves etc. and be able to pour water or antifreeze directly into the fresh water tank.1
- 421 Service/Maintenance & Recall Notices
