Does anyone carry a spare Hub 2022 320 S Boondock?
homerd
homerd Member Posts: 37
Does anyone carry a spare hub with a 320 S Boondock? If so, what is the part number and where did you purchase. Thanks
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
    MuttonChops Member Posts: 1,975
    Sorry, I'm confused.  Hub as in 'wheel hub with the bolts that the lug nuts screw on to' ?
    The TorFlex axles has a Spindle that is welded in place and then a Hub/Drum part that is placed on the spindle.  Dexter sells Hub/Drum replacement parts and kits . . . on wheel kit could be $500.
    Not sure why anyone would carry these as a spare.
  • homerd
    edited March 2022
    Just a hub with bearings. Bearings go bad just switch hub, usually a $60 part
    My unit has the Dexter 8-247 hub/drum.  Available at eTrailer
    Carrying one as a spare still seems to be major over kill for the average usage camper.
    With correct bearing maintenance using the EZ-Lube system on these axles, the likelihood of a bearing failure seems very remote.
    The forum has several interesting thread on Bearing Maintenance.
    here is one such thread - -
    Basic overview of Hub and EZ-Lube
  • homerd
    Thank you, I’m heading to Alaska and thinking hub much easier to change than bearings
