Does anyone carry a spare hub with a 320 S Boondock? If so, what is the part number and where did you purchase. Thanks
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
0 ·
The TorFlex axles has a Spindle that is welded in place and then a Hub/Drum part that is placed on the spindle. Dexter sells Hub/Drum replacement parts and kits . . . on wheel kit could be $500.
Not sure why anyone would carry these as a spare.
Adventures: 58 Nights: 405 Towing Miles 50,180
With correct bearing maintenance using the EZ-Lube system on these axles, the likelihood of a bearing failure seems very remote.
The forum has several interesting thread on Bearing Maintenance.
