BAL Leveler Storage in Propane Cover
jkjenn
jkjenn Member Posts: 6,423
Inspired by @Mercator, I drilled out the rivets holding the factory installed PVC pipe in my propane cover to see if my BAL leveler fits. It does! Barely, but it does! I used the pipe foam around the flat jack pieces that go on along the sides of the tire to protect things in the cover and also around the threaded bolt to keep it clean. And, in case you are wondering, my Rhinoflex sewer hose still fits on top! Bonus! Hat's off to @Mercatorfor coming up with this one!
  • Mercator
    Mercator Member Posts: 237
    Looks good.  The only difference with my set up is that I put it in with the 'legs' down.  It probably doesn't make any difference though which way it is oriented.
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
