Adapter for King Omnigo Portable OTA Antenna to painter’s pole
rcarlson1957
Member Posts: 265
For those of you who have King Omnigo Portable OTA antennas looking for easy way to put on extendable painter’s pole. This works great. Screws on end of painters pole and won’t come loose. Magnetic Pick-Up Tool Attachment, 3.20" Diameter, 0.440" Thick Magnet Assembly with Acme-Threaded Attachment for Standard Broom Handle, 65 Pounds Pull, 1 Each https://www.amazon.com/dp/B000N8NI7G/ref=cm_sw_r_cp_api_i_CD77CBB6D9GFDQFYXR75?_encoding=UTF8&psc=1
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
Thanks for the tip and link, @rcarlson1957. I've been contemplating going the painter's pole role route for my OmniGo antenna, so the information is very helpful.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
I’m glad you found something, Rick. That looks better then what I put together.2017 T@B 320S Max silver on silver “Tabin”. 2009 Toyota FWD White Tacoma Double Cab.Leonard & Ronna, (Fort Collins, CO)
”Need More Cowbell” -
The magnet doesn’t cause interference with the antenna?
San Francisco Bay Area
2013 CS-S us@gi
2015 Toyota Tacoma PreRunner Double Cab -
Apparently not Marceline, my cell booster antenna has a magnetic base also. Works just fine on top the TaB. That said, you need to fix a painted steel washer to the TaB’s aluminum roof for the antenna’s magnetic to attach to.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 915 Tips & Tricks
