Cracked Water Filter Cap, 2008 TAB
Alpine90
Member Posts: 1
Hey all, recently realized I've got a couple nasty cracks in this clear, plastic cap that screws off to clean/change the small mesh water filter near the pump. I hooked the water up last week and it was spraying through the cracks. Any ideas on where I might find a replacement for my 2008? Alternatively, looking at the picture attached, anyone have a good epoxy/sealant solution that may do the trick if I can't find another cap?
Get the model info of your water pump and you should be able to track down a replacement or call the manufacturer directly. It looks like freeze damage. I know if you only use blowout out method water stays in this cup depending if it's screwed on with it up or down.
Assuming this is a standard 1/2" strainer you can get those for $10 on Amazon. Less hassle than trying to track down the correct replacement.
