Alde touch panel removal
How can the Alde touch screen be removed from the wall? It seems likely the front pops off if its pried out at the right point, but where? I tried a bit of that w/o luck and don't want to break it. Similar question for the AIR8 control panel.
There have been posts about insulating around the Alde panel for more accurate temperature measurement, and for removal for repair. I'd also like to inspect how some of the wall is built, as for installing a grab bar.
2022 T@B 320 S Boondock, TV 2019 Toyota Highlander Hybrid
Bloomington, Indiana
    Here is a copy and paste from a post by Muttonchops that nicely shows the construction for a grab bar.
    “Am not sure there is any real 2x4 lumber in a model 320.  The 'Studs' and support lumber seem to be 1x2, 1x3 soft (light) wood.
    Would assume the 'Stud' in the bathroom wall NuCamp is referencing is the 1x? that can bee seen in the Shower Plumbing Access space.  Picture below.
    To mount the inside of Bathroom Grab Bar I removed the Tel-V to better inspect the wall construction and found there are 3/4 inch thick boards placed between the 'studs' to handle the Tele-V Mounting system & Tele-V weight.
    Bathroom Grab Rail is screwed into those boards, which are behind the thin shower wall paneling.  Believe that will provide the strength needed.  Plus that Grab Bar is more for balance control while moving than dead weight lifting.
