Propane not coming thru
kerilynvj
Member Posts: 28
Hello! Has anyone had any issues with propane not coming thru to the stove or use for the fridge? The propane tank is on - but the light is flashing on the fridge and stove will not light...This is the first use.
I find that it takes a minute or so for the propane to reach the stove the first time i use it each outing. And I also light the stove for a minute or so before the frig kicks in.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota -
it will come thru for a second and then shut off. Any ideas?
May be a problem with the tank and/or the LPG regulator. Try another tank. If you have a grill, try the tank on the grill to rule out tank issues.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Turn the tank on very s-l-o-w-l-y. Some of them have internal built in safety shut offs that block the propane if it detects a sudden flow that might be a leak. I also use every other suggestion made thus far to make both my stove and fridge light successfully. You will get it figured out.Dan and Liz 2019 TAB 400 BDL 2010 Toyota Tacoma V6 4WD TRD Sport
Thank you!
- 915 Tips & Tricks
