Water pump
hikerchick
Member Posts: 35
Is the water pump only used for dry camping or you supposed to use it every time
The pump should be off when hooked up to city water. Also a good idea to turn it off when not in use or at the very least if your leave your trailer.
The pump is for getting water out of the water tank when you are not hooked up to City Water
That’s what I thought thank you both!
