Tongue box lock
tsweet
Member Posts: 1
Hi. I’m new to the forum and a new owner of a 2021 T@B 400 Boondocks. There has probably been a threat relative to this question but I couldn’t find it.
Here is my question: Is there any easy way to install a lock on the front tongue box?
Thanks,
tsweet
Thanks,
tsweet
Yes, easy, but not trivial. If you are not handy with tools it is probably not easy at all. If you are at least a bit handy it is just a matter of measuring accurately and drilling some holes. I used two cam locks with tubular keys. Check the internet for sources. There are several. I used two cam locks from Industrial Lock and Hardware. At the same time I replaced all of the CH751 locks on the access doors with cam locks keyed alike to the locks on the front tub. I still only have one key to carry but it is not the same key that every other RVer (and potential bad guy) has.
For some reason I couldn't post more than one copied photo. Here is another.
And another
- 916 Introductions
- 72 Teardrop Groups & Links
