Tongue box lock
Hi.  I’m new to the forum and a new owner of a 2021 T@B 400 Boondocks.  There has probably been a threat relative to this question but I couldn’t find it.
Here is my question:  Is there any easy way to install a lock on the front tongue box?
Thanks,
tsweet
  • falcon1970
    falcon1970 Member Posts: 758
    Yes, easy, but not trivial.  If you are not handy with tools it is probably not easy at all.  If you are at least a bit handy it is just a matter of measuring accurately and drilling some holes.  I used two cam locks with tubular keys.  Check the internet for sources.  There are several.  I used two cam locks from Industrial Lock and Hardware.  At the same time I replaced all of the CH751 locks on the access doors with cam locks keyed alike to the locks on the front tub.  I still only have one key to carry but it is not the same key that every other RVer  (and potential bad guy) has.
  • falcon1970
    For some reason I couldn't post more than one copied photo.  Here is another.
  • falcon1970
    And another
  • Maxcamp
    Maxcamp Member Posts: 352
